NI 9853 CAN Signals Receive Example
Hi catherine,
How to get all available frames or various cycle time frames in CAN port using this method
Message 11 of 14
(839 Views)
Hi viswasewaran,
@viswasewaran wrote:
Then how to get all available frames in CAN node
By reading the manual of the device connected in that CAN node...
Hi catherine,
Did you notice Catherine is a retired NI employee?
Did you notice she visited the forum 5 years ago the last time?
Did you notice this thread is already 7 years old?
Message 12 of 14
(833 Views)
HI Gerdw,
Thanks for your replay, I am using NI-9853, Any example available to read Array CAN frames in FPGA  or any property node available to get how many frames in CAN node, for example serial port have a property Called Byte At a Port
Message 13 of 14
(827 Views)
Hi viswasewaran,
There is no "BytesAtPort" for CAN devices...
The NI9853 comes with example VIs, which explain its usage on cRIO/FPGA targets. To get an "array of frames" you simply read one frame after the other and put their contents into a FIFO from FPGA to cRIO target!
Message 14 of 14
(825 Views)
