TCP Communication error Hex 0*BFFF00A6 Eurotherm temperature sensor
Hi All,
I am using LabView 2013 and communicate Eurotherm 3504 via TCP/IP communication. I am using iTool to see and configure the Eurotherm 3504.
When I try to configure via NI max I got an issue. Read and write both are not working (Error  Hex 0*BFFF00A6). When I try to configure via TCP interface LabView-I got an error message like Error 56 occured at TCP Read.''Time network operation exceed the user-specified or system time out.
Read and write are working fine with iTool. I dono why this is not working with VISA interface.
11:35:48.531 05/11/2021 : System Debug : Remote Command Received: enablelisthiding
11:37:12.426 05/11/2021 : System Debug : Failed to access registry for writing
11:29:26.324 05/11/2021 : System Debug : Remote Command Received: enablelisthiding
11:29:26.325 05/11/2021 : System Debug : Remote Command Received: hideprivatelists
Please support.
(1,388 Views)
VISA?  TCP/IP?  What are we trying to do here?  I think it would be best to upload your code and the manual that goes with your instrument.
Bill
CLD
(Mid-Level minion.)
(1,343 Views)
It was a TCP communication. The issue was I was using different connection id for read and write.
Issue has solved.
Thank You!
(1,297 Views)
