NI 9474
I am new to LabVIEW environment, i am trying to use NI 9474 digital output module in real scan mode. but all the time, received the shared variable append error . I attached the circuit diagram and error. kindly help me out in this.
(2,184 Views)
Hi Learner,
where do you run that VI?
Do you run it on your cRIO target?
Is there a NI9474 module in your current target?
Is the project reflecting the current state of your hardware setup?
(2,176 Views)
Dear Gerd
I use NI 9474 Module and deploy it on Real scan resource on cRIO. i also attached the project hierarchy diagram.
(2,131 Views)
Hi Learner,
it's a long time I since I used a hybrid ScanEngine/FPGA mode of a cRIO.
Did you compile your FPGA resources (which will include the needed stuff for ScanEngine)?
(2,121 Views)
I already compile it on FPGA separately , the device and system working fine, but when i use directly through real scan , i have this issue, and have no idea why this occur.
(2,111 Views)
