NI 9234 with NI myRIO
@Jovan.N wrote:
1. MyRio has a USB port. There are examples of the community in which the USB is used as an Input.
In this case you can use the 9234-9162 with the MyRio. The signal will be acquired by the 9234, then sent trough the 9162 to the MyRIO, but you need additional LabView code to control the USB input. ( https://decibel.ni.com/content/docs/DOC-39006/version/2)
Unless something changed you cannot use a 9162 plugged into the myRIO's USB port.  To use the 9162 you need DAQmx which isn't possible.  If it was possible there wouldn't be space for it since the myRIO has very little free space.  Connecting USB serial devices, USB keyboards, USB cameras, and USB storage devices are supported because the Linux OS supports that.  Adding kernel support for USB DAQ devices would not be a simple task.
EDIT:  Here is some discussions on USB DAQ devices on a myRIO.
http://forums.ni.com/t5/Multifunction-DAQ/Connect-myRIO-to-NI-USB-DAQ-Board/td-p/2947590
Message 11 of 11
(611 Views)
