NI 9213
 I am trying to plug in a thermocouple into N-9213 and see if i can get measurments of temperature. I am very new to LabVIEW.. i am trying to see if i can get the temperatures in LABview Express ...
it gives the following error. I am not sure if i am doing the write thing. Can anyone help me how to go about this..
Error -88302 occurred at DAQ Assistant
Possible Reason(s): An internal error occurred. --------------------
Error -200486 occurred at DAQ Assistant
Possible Reason(s): Measurements: Specified channel is not in the task. Channel Name: cDAQ1Mod4_ai0
(3,870 Views)
Hey Shanky,
      One reason you might be getting that error could be due to not having that channel name in Measurement and Automation Explorer.  You'll want to check to make sure that cDAQ1Mod4 is the 9213 you're trying to reference.  As well, you may want to reference this post and this post, which describes a similar error.  It could simply be that there's something wrong with MAX. Let me know if either of those solutions doesn't work!
(3,847 Views)
The first error could also be caused by installing the NI-DAQmx on a non-administrator Windows account or just a bad install in general.  If the recommendation by Anita doesn't help, try repairing the DAQmx driver and make sure you are on an account with administrator privileges.  See other posts here and here for reference.
Alex Person
NI-RIO Product Support Engineer
(3,842 Views)
