NHR 4600 AC Load Read Waveform from csv File
Does anybody know if the NHR driver has a VI that would make it easier to read a waveform from a csv file, store it, and output it using the 4600 AC Load?  There are lots of VIs that come with the driver and I am unfamiliar with them.  Thank you in advance.
(2,376 Views)
Good morning,
Have you tried reading in the csv using file I/O functions like the Read Delimited Spreadsheet VI?
Read Delimited Spreadsheet VI - NI
Once the waveform is read into LabVIEW you should be able to output the file using your drivers.
Conner A.
Technical Support Engineer
(2,352 Views)
Thanks for the response.  I was able to figure it out as I found a VI in the driver that let me create a waveform based on angles and currents.  Thank you for the help though.
(2,347 Views)
