.NET Refnum
How to create.NET Refnum? I searched it through function   in LabVIEW, but it is not available.
Is it OK to Start with .NET Refnum, When I start LabVIEW integration with a dll
Rathan
(4,995 Views)
Accepted by topic author Pahee
That depends on the class.
If the class requires a constructor, you need to use the constructor node and select one of the constructors from the list. This will give you a reference you can use.
Some classes are static and don't require calling a constructor. You can use those by dropping a property node, right clicking and selecting Select Class>>.NET>>Browse...
If you have no experience working with .NET, you should look for some examples and tutorials on this site.
___________________
Try to take over the world!
(4,988 Views)
