Loosing runtime menu for a control when application is moved to a different computer.
I have assigned a runtime menu to a control (multicolumn listbox). I prefer to save the menu to a file instead of to the control itself to simplify the maintenance. This works fine in the development environment and in the built application when I run it on the development computer. However, when I move the application to the target computer, the custom menu is lost and the default right-click menu appears. The correct menu appears if it’s saved with the control.
Why does it behave like this? Have I missed some setting in the build specification?
Best regards
Michael
Using LV 2009 on Windows XP.
(2,759 Views)
Did you also make sure that you are placing the rtm menu in the exe system?
(2,753 Views)
my expiriences are collected here...
(2,734 Views)
