NAS for Fieldpoint?
My fieldpoint application generates massive amounts of data in a very short time. To help manage all this data, I would like to put a Networked Attached Storage (NAS) device on the network and strema the acquired data to it.  The application runs in real time on the Fieldpoint host, and I use a remote panel at a P to monitor it.  Does anyone have any experieicne in doing this, or ideas on how it would be implemented?
Mark Nikirk
Hell, there are no rules here...we're trying to accomplish something!!! - Thomas Edison
(2,510 Views)
hi there,
quick and dirrrty: if your remote PC is online all the time you could run a ftp - script on the PC to fetch all datafiles from the cFP to your PC and move them from there to the NAS. i think the stress for the cFP would then be minimal (because FTPing won't disturb your timecritical VIs) with no additional RT-Programming necessary. you could rename the datafile as soon as it has been closed and the FTP-Script polls for that file each 10secs or so. if the file already exists on the cFP you can add a counter to the filename. then the RT-App will save the data wether the PC or the NAS are online or not.
you also can use the DataSocket Read-function on your PC for a ftp-fetch.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,503 Views)
This sounds like a good solution....I'll give it a try.  Is there anyway to stream data to the NAS?
(2,501 Views)
