N Largest Array Items with Indices
I would like to build a simple VI to find the largest N items in an array with the index of each item.
Message 1 of 9
(3,624 Views)
That's nice.  Did you have a question?
Message 2 of 9
(3,623 Views)
LOL (crossrulz) too funny...
ouhaoran, have you tried the "Sort 1D array" VI ?
Largest X values (from N sized array) = N-X-1 to N-1.
Message 3 of 9
(3,620 Views)
But no kudo?
Don_Phillips wrote:ouhaoran, have you tried the "Sort 1D array" VI ?Largest X values (from N sized array) = N-X-1 to N-1.
Notice that the OP also needs the index.  So if you go that route, you first need to bundle the element and its index so you have an array of clusters.  You can then sort array of clusters and grab the first N elements of that array.
The method I was considering was to do this in a FOR loop.  Keep the array in a shift register.  Use the Max & Min function to get the max value and its index.  Use Replace Array Subset to set that index to the lowest possible number for your data type.  You can then repeat to get your N elements.
Message 4 of 9
(3,608 Views)
Thanks, crossrulz. The bundling idea makes sense. Will Labview automatically sort by the first item in the bundle (if the first item is the value at the array index, say)?
Message 5 of 9
(3,600 Views)
Yes, Sort on a cluster sorts by element 0 first then element 1 only if element 0's are the same
"Should be" isn't "Is" -Jay
Message 6 of 9
(3,587 Views)
An alternative is to use the Sort Array and then the Reverse 1D Array functions. Using a FOR loop take the N first values (the N largest values) and then use the Search 1D Array function the find the indices of these elements in the original array. You can use the FOR loop to build a 2D array where the first column is the element of the first array and the second its index in the first array.
Ben64
Message 7 of 9
(3,566 Views)
Ben64
The problem with this solution being that Search 1d array get the 1st match, if you e.g. have 3 20's you'll miss 2.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 9
(3,538 Views)
/Y
You're right. I missed that.
Ben64
Message 9 of 9
(3,525 Views)
