MySql
Hi all
I created VI with MySql in LV 85.
Now I work in LV86.
In LV 85 I created the table with Date/Time.
All was working.
When I run this VI in LV 86 the tables was created without Time, only Date (column Type).
The table "2 " was created LV85 and  table "1 " was created LV86.
Why is without Time?
Best regards
Iskander
(5,145 Views)
Not sure but you could use the SQL execute VI and then run a CREATE TABLE command.  Do this in 8.5 and 8.6 to see if you end up with different results.
(5,106 Views)
I have reproduced the same error with LV 2009 and MySQL 5.1.  It appears that DB Tools Create Table.VI is sending 'date' as the data type to MySQL, as you see from your 'DESCRIBE' statement.
What version of the Database Connectivity toolset are you using / did it change?
Are you using the same version of ODBC driver as before?
Did the version of MySQL change as well?
It appears to be a bug in the Database Connectivity toolset, but there's some chance that it's the ODBC driver. The version of MySQL shouldn't matter as DATE and DATETIME have been supported as distinct data types as far back as 3.23.
The toolset manual, page 4-2 seems to indicate that the toolset will map Date/Time to DATE.  Don't know if this has changed in the latest version of the toolkit, but even in DB Tools List Columns, it converts MySQL from DATE to Date/Time.
DB Tools Execute Query.VI seems to work fine though:
It's an easy enough work-around, but the bug is unfortunate.  Perhaps it's time for the DB toolkit to be revamped to fix this and its performance issues?
Matt
Update - checked with '0' and other values for size of Date/Time and it didn't make a difference.
Message Edited by MattWhitlock on 10-15-2009 10:44 PM
(5,080 Views)
Accepted by Iskander
Hi all.
Thanks for the help.
I did so.
All is working.
Best regards
Iskander.
(5,041 Views)
It will help the forum if you could mark the post that helped you solve the problem instead of marking yours
(5,027 Views)
I used DB Tools Execute Query VI to create tables how write MattWhitlock.
(5,005 Views)
