MySQL DSN files
Hi!
I'm trying to store data from LabVIEW in a MySQL database, I've foloved the folowing procidure (http://digital.ni.com/public.nsf/allkb/47A8CF66D5E3C8CC8625720A006139D6) and it all works fine. But then,  I would like to be able to put my path to my DSN in a string so that I do not have to specifie it every time I run the program. They say that you can do that in the last sentence of the tutorial, but I cant find my specific path. I did exactly as it sad in the tutorial, do anybody know how I can find thise address?
(4,429 Views)
Hi ollef,
you can only specify the path to your dsn file. Maybe this link helps to do what you need.
Mike
(4,420 Views)
Accepted by ollef
ollef,
Hello! Following that Tutorial you linked allows you to create at User DSN and according to the documents below isn't actually a file, but information stored in a registry. So, when using the DB Tools Open Connection VI you would wire a string control into the Connection Information Input of the VI with the Data Source Name of the User DSN that you created in Step 6 of the tutorial.
What Is the Difference between a System DSN, a User DSN, a File DSN, Universal Data Link (UDL), and ...
Database Source Name
Ben Sisney
FlexRIO V&V Engineer
(4,398 Views)
