MyRIO Motor Adaptor - Encoder Readings
Have you solved your problem?
Message 11 of 27
(1,214 Views)
I've tried in seperate loops etc and the same thing happens. It seems to be motor 3 will only count when motor 1 counts.
Message 12 of 27
(1,213 Views)
Ok, Do you want to use 1,3 and 2,4 together?
Message 13 of 27
(1,209 Views)
Yes, but each motor uses seperate encoders.
Motor 1-=A/ENC (MXP A)
Motor 2 = B/ENC (MXP B)
Motor 3 = C/ENC0 (MXP A)
Motor 4 = C/ENC1 (MXP B)
Message 14 of 27
(1,206 Views)
Sorry but I don't understand your program logic. You have 4 motors and 4 encoders, right? When you use them separately, are they work well?
Message 15 of 27
(1,203 Views)
All three work well except Motor 3. I've attached the code so you can see the connection made to the motor adaptors
Message 16 of 27
(1,201 Views)
So when you try to use Motor 3 separately, its work wrong?
Message 17 of 27
(1,195 Views)
Yes, the count direction is always the wrong direction. It only changes when Motor 1 count direction changes, as shown from the attached photo.
Message 18 of 27
(1,186 Views)
I asked about using only motor 3 without others, is it work well?
Message 19 of 27
(1,184 Views)
And do you use the same motors and adapters for MyRIO?
Message 20 of 27
(1,181 Views)
