My controller dosent get the feedback
Please read Colin's answer about the problem with the tach you're using. An please, in the future, don't attach bmp files. They take far too long to download. Save files as jpeg. Windows paint supports this format.
Message 11 of 20
(1,566 Views)
hi
I need to read some analog input.I want to do the fourth excercise of the labview manual.
I have the DAQ 7.1 software installed in my PC.But I donot have the DAQ borad.
CAn i still make use of the DAQ?
And what is the traditional DAQ?Can i build virtual channels using this.
PLs do gimme so info abt this.
Thanking you.
Message 12 of 20
(1,554 Views)
In order to do any DAQ applications, you need both a DAQ board and the DAQ drivers. I saw on an earlier post that you have a PXI device, what PXI board do you have (e.g. PXI 6220, PXI 6229,etc)? You might be able to use this board to perform the excercise.
Traditional DAQ is our old driver, now we use DAQmx. If your PXI device is supported on DAQmx, I would encourage you to use this API to do your programming.
Hope this helps!
LA
P.S I would appreciate it for next time if you could post your DAQ questions under the DAQ section of the forums which you can find here
Message 13 of 20
(1,530 Views)
hi
I am using motion assistant to rotate my motor and then it automatically creates the labview code.Now in the labview code i have to add the user interface ,i have to keep a knob for specifying the speed,and draw a graph for the RPM.Can anyone pls help me with it?Qr it wud be helpful if u can gimme some useful tutorial link relating to my work.....
pls help...
Message 14 of 20
(1,521 Views)
hi
Thanx for the reply.|I dont have a PXI device.......Initially I thought that i have a pxi device because i saw it under the Devices and interface .I just have the PCI card..
thank you
Message 15 of 20
(1,520 Views)
If you only a have PCI 7342, then you need to buy a DAQ board in order to read some analog inputs and do the fourth exercise of the LabVIEW manual.
Hope this helps,
LA
Message 16 of 20
(1,504 Views)
how to stop the motor while using PCI 7342 (servo motor)?
Can anyone send me a example?
pls help
Message 17 of 20
(1,481 Views)
sumitha:
I just came across info that the newly released DAQ 7.4 can simulate hardware, that is, you do not need a card in your system to run code. You may want to look into this.
Message 18 of 20
(1,477 Views)
Hi
Thanx for that info...
I looked into it and In the device support I didnt find PCI 7342....Do u think it supports PCi 7342?
Message 19 of 20
(1,471 Views)
Hi Sumitha,
Let me mention a couple of things.
First, you should probably create a new thread when you have a new question. This will help everyone see that there is a new question that can be answered. If everything is within the same thread, it makes it a little bit more difficult to understand your post. Additionally, creating your question within the proper section (i.e. 'DAQ' or 'Motion') can also be very helpful. Please do these things in the future.
As for your question, If I understand you correctly, you are asking if DAQ 7.4 will support the PCI 7342. The DAQ drivers support the Data Acquisition product line, and are not needed for the PCI 7342. If you want to look into the functions of the DAQ driver, you certainly can, but keep in mind the DAQ driver and 7342 are completely unrelated.
You were also asking about how to stop motion with the 7342. Within the interactive portion of Measurement and Automation explorer you can select to 'Kill', 'Decelerate' or 'Halt' motion. Within Labview, you can use the "Stop Motion.vi" which is on the Flexmotion palette in the 'Start/Stop' motion folder.
Hope this helps,
Robert
Message 20 of 20
(1,457 Views)
