My Yokogawa WT500 power meter does not show up in NI MAX.
I'm trying to communicate via USB with a Yokogawa WT500 power meter but it won't show up in NI MAX under "Devices and Interfaces". I'm running LabVIEW 2013 on Windows 10. I have NI-VISA 16.0 installed as well. When I plug in the device, it shows up in Device Manager under "Other Devices" as "WT500".
It should show up under "USB Test and Measurement Devices".
How can I fix this?
(5,491 Views)
Accepted by topic author IsaiahRyan
I solved it!
I just downloaded the latest Windows driver for USB Test and Measurement Device (IVI).
Here is where I downloaded it from: http://www.drivermax.com/driver-download/0/USBTESTANDMEASUREMENTDEVICE/IVI+Foundation,+Inc/USB+Test+...)
(5,474 Views)
@IsaiahRyan wrote:
I solved it!
I don't know if I would trust anything from a sketchy outlet like Drivermax... You are just asking for malware.
Here is a link to the WT500 "Certified LabVIEW Plug and Play Instrument Driver" from the NI Instrument Driver Network,
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=50008A07FB292B33E04400144F1EF8...
 And here is a link to get them directly from Yokogawa
https://y-link.yokogawa.com/YL008.po?V_ope_type=Show&Download_id=DL00002058&Language_id=EN
=== Engineer Ambiguously ===
(5,464 Views)
Oh and IVI shared components are best downloaded from the IVI Foundation.
http://www.ivifoundation.org/shared_components/Default.aspx
(5,440 Views)
Yes, it would be best to download straight from IVI Foundation.
(5,427 Views)
