Multiplying element in array if the value is under a certain threshold
Ha Ha.
Well, the math itself wouldn't be a hack.
But the -1 and +1 to work back and forth to jockey around the 0 and 1 you get out of the boolean to comparison.  It took me a couple minutes to figure how the math was manipulating the gain to get the result.  It starts to feel a little Rube-ish. Smiley Wink
I like to be able to look at the code and quickly see what it is doing.
Message 11 of 16
(1,085 Views)
@RavensFan wrote:
Ha Ha.
Honestly the correct thing to do to make it easier to understand is to replace the increment and decriment functions with add and subtract using the integer array.  But, since the int there is certain to be either 0 or 1....
You do the math....:D
"Should be" isn't "Is" -Jay
Message 12 of 16
(1,015 Views)
Another way:
Ben64
Message 13 of 16
(1,006 Views)
What impact does the IR&C have compared to GT?
I agree that it will work but, did you benchmark the code and find an advantage?
Message 14 of 16
(1,000 Views)
I take back my earlier agreement.  Toss a NaN in there.
And how did you actually scale the inputs by a factor of x?
Message 15 of 16
(998 Views)
This is the disadvantage here, it is fixed to 2 but in this case this is what the OP wanted.
Message 16 of 16
(992 Views)
