Multiple plots on a single waveform graph outside of loop
Hi there,
I am using Linx to sample 4 analogue data streams from an arduino uno. I am using a template VI from the NI community (see attached). The VI uses a waveform chart inside the loop which samples all 4 channels correctly (I've tested this).
I would now like to create a waveform graph outside of the loop that displays a time plot of the 4 seperate channels after each run of the VI. When I tried doing this I could not connect the cluster data type to a waveform graph. If I connect the output of the Analogue Read VI directly to the waveform graph (after tunnelling) it plots all four channels as a single stream of data (think they actually cancel each other out). Is there a way to seperate these data streams outside of the loop? (Sorry if this seems trivial, I am still quite a novice with LabView and don't have too much time for tutorials as this is part of a time pressured project.)
Thank you for any explanations or solutions.
(2,175 Views)
Hi Mike,
So a LabVIEW novice is forced to fulfill a "time pressured software project"?
Why did you even take this job?
Learn LabVIEW, then start using it…
The LabVIEW context help shows which datatypes are expected by charts and graphs. Did you follow that context help?
Unfortunately I cannot open your VI due to its LabVIEW version.
A graph shows just a "single stream of data" (aka a single plot) when you provide a 1D array. As the context help shows it expects a 2D array to display several plots…
(2,151 Views)
Thanks for the reply. I've managed to find a solution with some context help Smiley Happy
(2,138 Views)
