Multiple plots in Express XY graph
I'm trying to have several plots in an Express XY graph and use it without clearing data on each call - like a chart.
On the Y Input, I'm inserting an array with 2 values (1 for each plot) and in the convert to dinamic data I choose 1D array of scalars - multiple channels. The problem is that there's only one plot in the graph.
See attached example test.vi
Can anyone help?
Thanks.
(5,546 Views)
Hi Paulo
You need as many x arrays of values as y arrays of values.
See attached doc
Cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(5,526 Views)
Hi Alipio,
It worked,
Thanks a lot.
(5,523 Views)
My multiple plots are now working quite fine, but now I have a problem that after some time sending data to it, the load of my processor starts going up a lot.
I can imagine that I cannot send data to the graph forever ('clear data on each call' flag is off), it should have a buffer length, but I cannot find it.
Can anyone help?
(5,513 Views)
Hello
Ok, you will have to convert express vi to standard vi ( Open front panel/ convert).
Then, go to block diagram and limit amount of data using "array subset" function.
If you have toolkit to create express vis, you can get it back to express. If not
use it as a regular vi.
Greetings
Alipio
(5,502 Views)
I was affraid that was the case...
Thanks for the help.
(5,500 Views)
