I would like to use PCI-6731 board and traditional DAQ to generate N updates (triggered). I need to use 2 buffers filled with 2 different waveforms before start the generation (to avoid speed problems). I know how to fill these buffers (VI AO Buffer Write - in advanced analog output) and give them numbers (1,2).
The problem is that I don't know how to tell to the AO Start VI which buffer it should take (the 1st or the second).
I tried to open AO Start VI to modify the low level functions and I found the "staging list", on which the buffer number is specified. So I made external connectors in order to modify this information. Normally, I can change the array specifying the buffer number. But when I enter the buffer number to this array, I have an error message :
NI-DAQ LV: The specified device does not support the requested action (the driver recognizes the device, but the action is inappropriate for the device).
What should I do to use 2 buffered analog output ?
Any ideas and suggestions welcome, thank you !!!;-)
K.
NB : using Labview 7.1.
