annulla
Visualizzazione dei risultati per
Cerca invece
Intendevi dire:
Multiple instances of the same VI?
Hi all,
I had read the disscussion so far happen on this topic. I had tried out using the VIT to run the multiple instance of the same vi. I had put the VIT by dragging teh icon also but still it stops when vit called and run the main program after completion of the vit. I want to run multiple instance of the same vi at a time. Plz let me know if any one has the solution.
Some suggsted to visit SearchVIEW.net and find Kyle Gupton note on that. I also tried it out but not get any such note. Plz guide me how to solve the problem.
Thanks.
Vishal
Messaggio 1 di 2
2.599Visualizzazioni
Hi Vishal,
Please find attached VIs based on the article "Cloning Front Panels -- Refinements to a VI Server Technique
(http://zone.ni.com/devzone/insights.nsf/2d17d611efb58b22862567a9006ffe76/3f078841321aca4686256acc00685b15?OpenDocument)
The VIs are generated in LibVIEW 6.0.2
Ray Farmer
Scarica tutti
Messaggio 2 di 2
