Multiple file path using Path File Control
Hello everyone!
I would like to know if it was possible to select multiple files with a single "Path File Control". I think it would generate (if this were possible) an array of paths.
Is it possible to do this? If so, how can I do it?
Thank you so much.
Davide
(2,695 Views)
You need an array of the file path controls.  Unfortunately, you still have to select one file at a time.
(2,655 Views)
Accepted by Giadavid
I did it.
For all those who have the same problem, use the "File Dialog" located in Programming> File I / O> Advanced File Functions.
Once selected, go to the Properties and remove the check from the "Limit selection to single item" checkbox.
The result will be an array of usable paths.
(2,645 Views)
