Multiple choice box
Hello.
I need help: I cannot check one box and drive uncheckable the 2 other boxes.
In the image below, I encircled the concerned area.
Thank you very much.
(5,765 Views)
Accepted by AlainKabs
It seems to me that you picked the System >> Boolean >> System Radio Button. This is the wrong one. There is (on the same palette) the System Radio Buttons (plural!), which is a collection of Radio Buttons. The default configuration is that only on of these can be "active".
Norbert
Norbert
Expert: Geometry
(5,744 Views)
Yup, Checkboxes are used for selecting a value or not like a boolean.  There is a version of a checkbox which has a True, False, or Mixed option so it has three states but it is independent of all other controls.  A radio button is where you must select one of N choices, and picking one, will turn the others off.
For instance this should be a radio button because there is only one option.
What is your favorite food?
Pizza
Burger
Apply
But if I ask this question you could select multiple items, so a checkbox would be better.
Why do you use LabVIEW?
It is easy
My boss said to
I enjoy graphical programming
(5,701 Views)
Hello.
Thank you all, the answer works fine: System Radio ButtonS is exactly what I needed.
Have a nice weekend.
Alain.
(5,659 Views)
