Multiple channels NI-DAQ
Hi!
I have a problem regarding data aquisition from multiple channels. I get data from one channel at the time, but when I try to make a similar code to get data from another channel, it will not work. This can be done with DAQ-assistant, but I want to avoid that solution, as it slows the program quite a bit.
The snapshot-attachment show how this is done for 1 channel. Can I use a similar programming solution for data aquisition from multiple channels?
Thanks for your help.
___________________________________
Is my avatar the dog from the fraggle rock?
(7,365 Views)
Here is the .VI as an attachment.
(7,363 Views)
Accepted by automasjon3ea
You just have to specify multiple channels in your task - i.e. Dev1\ai0:1 and change the DAQmx Read to N Channels. Go to the task in MAX and click on the Add channels button. Follow the directions.
(7,355 Views)
Can you please tell me how I can use random multiple channels? For continuous channels, say 0 to 5, I type ai0:5 . What should I do if I want random channels, say 4,7,10,13?
Dheeraj Bharadwaj
IIT-Madras
(7,278 Views)
Dev1\ai3, Dev1ai6, etc.
You don't have to enter this manually, you know. The DAQ Assistant tells you how select non-sequential channels from the list of all. The DAQmx physical channel control has the same capability when you click in the dropdown and select 'Browse' and then CTRL-Click.
(7,271 Views)
Is there a way using the DAQmx functions to read from multiple channels, but have different sample modes (RSE, Differential, etc.) for each?  This is very easy to do with the DAQ Assistant because you can individually select for each channel, but I can't seem to get this to work with the DAQmx functions, which I need becuase my loop times need to be minimal. Thanks in advance!
(7,182 Views)
