Multiple ROIs
I am working on the IR images received through a TCP/IP client application. Once the image is received, I need to produce the histogram of the selected area. To select the area of interest, I am using various ROI tools. Now, when I use say a line ROI tool to produce a ROI, I need to retain the ROI produced by the say, rectangle ROI tool. That is, I am using multiple ROI tools to select the various ROIs on the image and every time when I use new ROI tool, the ROI selected by the previous tool must be retained.
(7,666 Views)
Here's a quick example (LV2010) of how to do it (multiple ROIs).
The idea is to catch mouse up events on the image display and for each of then see if the ROI has changed and if it has, then combine the previous ones with the new one.
Hope this helps
Epictetus
Antoine Chalons
(7,661 Views)
Thank you very much for the response. But I am using LabVIEW 2009. So, if you can send me the example for the same.
(7,650 Views)
Sure, here it is in LV8.5
Hope it helps
Epictetus
Antoine Chalons
(7,647 Views)
Thanks a lot. This solution is working for me.
(7,635 Views)
Also, if you hold down the 'Ctrl' key when drawing new ROIs, the old ones are not erased.
Randall Pursley
(7,629 Views)
Good catch, i didn't know about that Smiley Surprised
Epictetus
Antoine Chalons
(7,626 Views)
