Multiple Plots versus Absolute Time in one Chart
Hi!
I need to plot multiple values against time on a single chart. How do I do that?
When I try to use "build waveform", it accepts only single Y-value and timestamp. In the case where I use "bundle" it doesn't accept timestamp.
The attached image shows "bundle" variant. It is almost what I want except Y-Axis is always begins with 0.
(3,438 Views)
Accepted by e_rush
Hi rush,
What about an array of waveforms?
You can set the X axis scaling using property nodes (multiplier, offset)…
(3,424 Views)
Changing offest to current time works like a charm. Thanks!
(3,410 Views)
