Multiple DB tools insert data Error Code: -2147217900
 Hi All 🙂 ,
I'm new to LabView. Right now I'm using version 8.2.
I have browse the topic but i dont seem to find what i need.
I have two question and I hope you guyz can help.
1. I am doing a program and i need to insert my data in SQL.
Previously, I have done this using single DB Tools Insert Data.vi  due to only one table involved. It was OK.
For this case, I need to push about 8 clusters of data inside database every 5 seconds.
I'm not sure on how i should wired the vi's if i'm using 8 at once.
I have tried connecting it parallelly from the open connection tools and serially from one insert data tools to another.
Is this the correct way to do it? Please advise. I have attached the insert data part of my program.
2. Previously when i try to connect all 8 in serial, the vi runs, however, it doesnt pass the data to the database.But when i stopped the VI and tried to run again, the error code -2147217900 come up. Can someone advise on the reasons why it occured?
Please advise and million of thanx in advance.
regards,
Roziela Sharib
(4,294 Views)
Accepted by Aleizor
study the links here and post if still problem persists
Mathan
(4,285 Views)
Thank you. :smileywink:
regards,
Roziela Sharib
(4,277 Views)
Glad to help Smiley Happy
(4,262 Views)
