Multiple Channels Agilent 2000 3000-x
OK. I'm now running my waveforms to a Waveform Graph, which makes sense, but I'm trying to record the waveforms with a time stamp so that I can run my test over night and look at the data in the morning and the Waveform Graph VI doesn't seem to want to do that.
Thanks for the help!
Message 11 of 17
(756 Views)
Hi Qube,
a graph only displays data, it does not "record" them…
Message 12 of 17
(754 Views)
I would recommend saving the data to a TDMS file or some other type of file.  Then you can process the data at your leasure.
GCentral
Message 13 of 17
(751 Views)
Do you know of any ways to get the AC RMS value out of the Waveform data? I should be able to record that to a table with a time stamp.
Message 14 of 17
(733 Views)
Hi Qube,
there are a lot of functions in the signal processing palette…
Message 15 of 17
(730 Views)
Alright guys, I got a nice RMS reading from two channels of my scope with a time stamp! Thank you very much for all of your help! I'm not sure what to accept as a solution since every post was a sort of a solution...
Message 16 of 17
(723 Views)
You can select multiple post as solutions.
Message 17 of 17
(716 Views)
