Multilanguage user interface
Thanks a lot R3g, I had no idea there is such a great feature.
OK
Message 11 of 22
(3,613 Views)
Accutally I can't find the UTF8 to ANSI.vi and the to Unicode String.vi. I've installed the unicode VI Lin but thes VIs are missing. Can somebody please help me.
Message 12 of 22
(3,471 Views)
Message 13 of 22
(3,461 Views)
Thank you!
Message 14 of 22
(3,423 Views)
Hello, what is that blue FP icon? I can't find this in pallet.
Message 15 of 22
(2,256 Views)
This?
Assuming it's this one, then it is here:
vi.lib\Utility\traverseref.llb\TRef Get All FP References.vi
It ships with LabVIEW but only appears in the palette if you install this "Hidden gems" VIPM package, or a similar one, or add it manually:
https://www.vipm.io/package/national_instruments_lib_hidden_gems_in_vi_lib/
Message 16 of 22
(2,253 Views)
Vow, that was fast, thanks very much.
Message 17 of 22
(2,246 Views)
I know it's an old post.
I'm trying to set unicode boolean text.
With caption of booleans it's all ok, but when I try to write boolean text, via boolean.txt property or even multiple strings array, it does not work.
I tried to copy manually unicode text before starting the program, to force as unicode to the string I am passing to the property. Nothing to do.
All boolean text is spacing between chars, as is interpreting as asii.
Any idea how to solve this?
Message 18 of 22
(70 Views)
Hi Pinco,
There is an hidden property for Boolean text :
I don't remember which key in LabVIEW.ini makes it available, you can try with either :
UseUnicode=TRUE
or
SuperSecretPrivateSpecialStuff=True
Message 19 of 22
(58 Views)
Hi PinguX,
I already turned on both of them, and also turned on Interpret as Unicode just before setting the txt.
Nothing happens in developping.
Message 20 of 22
(47 Views)
