Multicolumn listbox with drop down menu item
I want to build a multicolumn listbox  with a column having drop down menu (enum type). Can anyone suggest a way how to implement it.
Ravi
(5,582 Views)
Make an XControl.  Here's one for Tables,  use it as an example to build one for MCLBs.
(5,557 Views)
Thank you for the reply. Let me try it.
Ravi
(5,542 Views)
HI,
I tried to run the example you posted. I couldn't find drop down list menu in any cell of the table.
I added .ctl file to the front panel and gave a combo box as input. Is it the way how it should be used??
(5,511 Views)
place the xctl on your fron panel, in its context menu you'll find "Custom properties". (This is only shown, when the Control is not selected). There you can edit the behaviour of the XControl.
This behaviour is programmed via the support-VIs, Listed in the Library- window. This is accessible with a double-click in your file-explorer.
Greets, Dave
(5,505 Views)
There is a QControl that does that exact thing. You can find it in the Community Contributed QControls on the QControl Enthusiasts Group:
It is called the DataGrid QControl.
p.s. I’ll never use an XControl again. Too many issues with them.
Quentin "Q" Alldredge
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
(5,473 Views)
