Multicolumn Listbox
I don't bother you,but i need you help,today i met some proble for use teh Multicolumn list box in labveiw.i can soft disable the one Row .but i don't known how to soft enable the  row. i only can manual enable the row on the front panel.(right click mouse,you wil got it), so would you tell me how to solve this issue?
by the way,i can use the other way to solve this problem,but i think it can manual enable,so it also  possible can soft enable.
(3,697 Views)
I think you want the "Disabled Items" property for the multicolumn listbox. Just set the rows you want disabled with that, all others will become enabled.
(3,687 Views)
Of course ,but i don't want to do that.i only want to control the one row , for example firstly make the many row has disable, you can use the "double click row get the row number" this function for these disabled Row,  so now i want use this "row number" to make accordance row is enable.(one by one to control ,point to point).
(3,682 Views)
I don't see how controlling all the rows stops you from controlling just one.
Here's an example just double click to enable a row.
(3,673 Views)
I got it,thank you very much,!!!Smiley Happy
(3,667 Views)
