Multi-threaded error handling method
I have a multi-threaded application.  When an error occurs in any of the threads which causes the system to fail, all of the threads throw an error and display an error dialog box.  I am thinking about removing the call to the error handler in the secondary threads and instead send the error to the main thread for disposition.  Is that a common design pattern?  Is there a better way to do this?
(3,002 Views)
Accepted by topic author kc64
Not as common as it SHOULD be.
We use an Event Logger that passes all errors to a background process that logs them to file for review later. That is the minimum. If the errors a fatal then we adjust the app design to react accordingly when bad things happen.
(2,999 Views)
