Multi thread access to a .Net dll?
Hello
I do have a .Net dll which runs two threads in parallel. After using the dll in LabView it seems that I have only access to the thread where I do program my HW. I know this because the programming runs till the end.
Now I have the problem that the other thread - which runs the status update - is not accessible and therefore I do not have any status information!
What I need to do to have access to both threads of this .Net dll?
An example would be great therefore.
thanks in advance
(3,046 Views)
Hi, could you post some example VIs so I can reproduce it on my PC?
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
(3,010 Views)
Provided they are both running in the same process context you should be able to put all of your dll calls inside a single Action Engine that in turn is shared between the two threads.
Just triyng to help,
Ben
(3,006 Views)
