Multi-channel Sequential Controlling Pulse Generator Design
Hello, all,
I need to design a Labview problem as a Multi-channel Sequential Controlling Pulse Generator and output through DAQ card. The required digital pulses are showns in the attachment.  Time scale values are shown on the top as an example. CLK's duty cycle is 0.5. x1 and x2's value need to be programable.
Could anyone give example codes? Or, give me any idea to program these pulses?clock.png
(3,326 Views)
I do not know which zone is good to post this question. Which zone is good, Labview or Multifunction DAQ?
(3,308 Views)
Digital I/O since that seems to be what you need to use. You can ask the moderator to move either of your posts. You also need to provide the hardware you are using.
(3,304 Views)
Can I edit my post? I cannot find it.
If I can, I will delete the duplicate post and update the hardware DAQ info.
(3,295 Views)
