Multi-User Environment
HI,
So if you have so many labview machines then what is the problem,just make a copy of the code into different machines and run the test program.
vicky
Message 11 of 18
(1,495 Views)
Thats is what i would like to know. Do i have to copy all my Vi's to those computers, or can I store it on a central server. Obviously i must make an installer or Exe for it.
Press "F" to format your disk, or "F" to cancel.
Message 12 of 18
(1,495 Views)
Ok ,so what you do if you dont want to create a exe or application is just create a .lib file and save it in all the pc's and use it.by this you will have only one file to handle.
hope this solves your problem.
vicky
Message 13 of 18
(1,488 Views)
Thnx!!! It looks like it worked. I created a. LLB file and i can open this and work on every computer with it. But i have only 1 issue. I have a configuration file, that is read with ReadKey.vi (and open configuration data) and i would like to add this to the LLB file (if that is possible).
As you can see i'm using the Current Vi' path as directory. When i'm using the .LLB file the program gives an error that it can't find the configuration file:
Could somebody tell me how I can add the Configuration file to this LLB file or give me a good hint how to solve this problem ?
Message 14 of 18
(1,470 Views)
Use a probe to read the path which is passed to the config file vis.
I think you made it correctly, but you just append a filename without an extension. Is this correct? If you have a *.ini file you have to appen "EfficiencyTest.ini" to the build path function.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 15 of 18
(1,465 Views)
Yep this works, but i made it .ini now to be sure 🙂 But i Probe the Vi path using the "Current VI's Path". Should i store this configuration file on a default place ? I would like it to be "compiled" with the LLB file if this is possible.
Message 16 of 18
(1,462 Views)
As far as I know it is not possilbe to store any other files than *.vi, *.vit, *.ctl in a llb.
And what do you mean with "compile with the llb file"?
Using LV8.0
Message 17 of 18
(1,453 Views)
Maybe not the right word, but i meant that you can add (compile) this file with the LLB file. If you are not sure you can add an external file to this LLB file, i think i will store it on a central place 🙂
Message 18 of 18
(1,450 Views)
