Two Graphs In the Front Panel
I am trying to have two graphs in my front panel. I am having difficulty. The VI is attached. Can anyone help?
(2,828 Views)
Do you mean two signals on the same graph or two graph indicators on the front panel?  What is happening with your vi? (I am missing a VI so I couldn't get it to run)
Brian
(2,826 Views)
I am trying to make a VI with two graph indicators. I have reattached the VI. There are some errors. The LV is in 6.0.
(2,810 Views)
I still don't understand, but I will add a few comments.
I see one chart. It seems you want to add another chart.
What is the problem with that? Where do you want to place it?
You're building an array. Why?
Do you want 2 plots?
If so, you need to bundle the plots, not build them as an array.
Your loop runs only once. Why?
The chart is updated only after the loop finished running. Why?
You have some problems where in some cases you have an array and in others you don't. If you want to continue passing the old data, you should use a shift register.
If this didn't help, you should tell us what you are trying to accomplish.
___________________
Try to take over the world!
(2,798 Views)
