Multi-Color Indicator
To create a multi-color indicator:
1. Start with a classic radio buttons control.
2. Replace the radio buttons with any style of indicator that you like.
3. Add as many more as you need for your color set.
4. Change the OFF color of all the indicators to transparent.
5. Change the ON color of each indicator to a different color.
6. Stack the indicators on top of each other.
7. Change the background and border colors of the cluster to transparent.
An example is attached.
(6,774 Views)
What's wrong with using a simple colorbox? 😄
(6,768 Views)
Was this post suggesting something or was it asking for help or advice?
(6,760 Views)
If you have a limited number of color options you need to support in your application example Red Yellow Green you can define an enum (or another numeric source) to have three values where "0" is red, "1" is Yellow and "2" is green.
Using the approach outlined above you just wire the numeric to the "Multi-Color Indicator".
If we used a color box we would need a look-up table between the two.
So i read this as a Micro-Nugget.
But then again, a Picture Ring with the pictures being colors would be about the same.
Ben
(6,740 Views)
Ben
I love rings for this ( use non-sequential values)- use hex display for the values and
Red    FF0000
Green 00FF00
Blue   0000FF
The real beauty of this method-  Durring development you can make an vi like this- SWAP indicator/control on both - use the color picker to choose nice colors and IF you allow undefined values at runtime- the values you chose show up in RGB.
"Should be" isn't "Is" -Jay
(6,724 Views)
