Ms Access examples
Hi, I know that are examples to use ms access databases with labview on the
NI site, but what I want to do requires only simple examples. Like open,
read, write and close database. So if anyone of you can send me simple
examples I will appreciate this
Eric
(2,898 Views)
Are you using the SQL Toolkit or something else. If you're trying to use ActiveX, I'm not sure that there is such a thing as a simple example. I have examples for both. Let me know what you want.
(2,898 Views)
Dennis,
I'm starting to use ActiveX for Access and at this time I'm not able to purchase the SQL toolkit. Would you please be so kind as to send me your ActiveX examples? BTW I'm also restricted with LV 5.1.1...hopefully this spending freeze will end soon.
Gerry
gsorensen@comspacecorp.com
sorensen@vetec.com (home office)
(2,898 Views)
