Inverse laplace transform.vi ?
I need to use an "Inverse laplace transform". As I find the "Laplace transform real.vi" , I just want to know if the "Inverse Laplace Transform.vi" exist and where i can find it.
(2,994 Views)
At least it doesn't exist in my LV(6i). Anyway, when you want to search for a function or control use the search feature of the palette.
Maybe you can workaround your problem with the discrete Laplace transform based on the Fractional Fast Fourier Transform (take a look in the help)
Good luck!
(2,994 Views)
