Mouse for measuring distance
Hello everyone!
I´ve been trying to make some program to measure the distance "traveled" with my optical mouse connected with USB to my computer.
I´ve checked a lot of the posts, but I could not find what I´m intending to do.
I want to know the distances in X and Y, independent of the monitor´s size, I mean, even if the pointer is at the top of the monitor, if I keep moving it up, to count the vertical distance until I say so, the same with the horizontal movements..
Any advice?
Thank´s!
(3,547 Views)
For something like this you'd most likely have to delve into operating system calls, since an application would only see what the OS passes to it, and in the case where the mouse is pegged at the top of a monitor and the user keeps moving it up, the app would not see a change in Y coordinates. The OS, on the other hand, would see the messages coming from the mouse and basically "clamp down" on the Y coordinate. What operating system are you using?
(3,513 Views)
Thanks mercutio!
I have the Windows XP version 2002.... Which should be the firsts steps to do something like that?
(3,472 Views)
Well, without delving into the Windows API I can't give you a direct answer. My suggestion is to look through MSDN since that contains the documentation for the Windows API. You can also try Google to see if anybody has done something similar.
(3,432 Views)
Thank you mercutio, I will get into it, and see what happens...
see you...
(3,414 Views)
