Creating an Executable, Analog Input (sensor) doesn't work
I had a question regarding creating an executable via labview for my project to be used on other computers.
When I create my executable, everything works fine except my analog inputs. Like I can't get any reads on my sensors from my executable. It works just fine on my test computer however when I transfer over it via executable (which doesn't have labview on it) the program isn't reading the sensors.
I used both analog output and input in my program the difference is that for the output I used the standard DAQmx VIs and for the analog input I used the DAQ assistant. I don't know if that has anything to do with it but the output works, just the input doesn't.
I attached my VI to make it easier for you guys to answer my question.
Justin
(2,883 Views)
Accepted by topic author Justin Lin
nevermind! fixed the problem
(2,868 Views)
