Mouse event in embedded internet explorer
@labmaster wrote:
Can you recommend some material for this topic?
No, nor can I give detailed explanations, because I'm not in that field either. There should be enough material available online.
In any case, you should consider that ActiveX and .NET are different - generally, I would suggest using .NET if you can, so I would suggest you look at the .NET examples and search online.
___________________
Try to take over the world!
Message 11 of 11
(1,073 Views)
