Mouse Move Event Outside vi
Vasanth,
Again, you need mouse hook. In the other words you must create DLL, where you should register your hook by calling following function:
     hook = SetWindowsHookEx(WH_MOUSE, (HOOKPROC)msghook, hInst, 0);
Application instance you will get from DllMain something like that:
BOOL APIENTRY DllMain( HINSTANCE hInstance,  DWORD  Reason,  LPVOID Reserved)
 switch(Reason)
     case DLL_PROCESS_ATTACH:
  hInst = hInstance;
So, now every time when mouse moved your hook callback function will be called:
static LRESULT CALLBACK msghook(UINT nCode, WPARAM wParam, LPARAM lParam)
    LPMSG msg = (LPMSG)lParam;
    if(msg->message == WM_MOUSEMOVE || msg->message == WM_NCMOUSEMOVE)
   //Do something for inform LabVIEW about movement, for example set LabVIEW occurence
    return CallNextHookEx(hook, nCode, wParam, lParam);
} // msghook
Do not forget to remove your hook when application will be finished:
UnhookWindowsHookEx(hook);
Its a quite terrible to debug this, but in general it should work.
with best regards,
Andrey.
Message 11 of 15
(1,210 Views)
Andrey,
         Thanks. Let me try this.
Vasanth.
Ya Ya
Message 12 of 15
(1,203 Views)
Andrey,
          I dont have a visual studio installed in my pc. Can you please provide the functions you have given as dlls?
Vasanth.
Ya Ya
Message 13 of 15
(1,189 Views)
There are functions:
If you haven't MSVC, then you can use any freeware C compiler, which able to build DLL for Win.
Also may be possible to create DLL in LabVIEW, but not sure about callback...
Here is good starting point:
Andrey.
Message 14 of 15
(1,182 Views)
Andrey,
         Thanks. I will look into it.
Vasanth.
Ya Ya
Message 15 of 15
(1,169 Views)
