Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
09-27-2017 06:05 AM
Hello All,
Working with LabVIEW 2017 f2 on Windows 7 I experience the following problem:
When I move the mouse cursor in a string control or indicator with visible scrollbar from the text area over to the scrollbar, the mouse cursor doesn't change from the text-Cursor to the expected Arrow. When coming from outside the controls area to the scrollbar it remains the arrow until the cursor enters the text area.
I do not see this with LabVIEW 2015.
Is this reproducable by you?
Solved! Go to Solution.
09-27-2017 07:38 AM - edited 09-27-2017 08:02 AM
Yes, reproducible. Same for horizontal scrollbar.
There seems to be a small difference between run time and edit time (although could be coincidence):
Run time: cursor will not change when entering scrollbar.
Edit time: cursor is set to text edit icon when entering scrollbar.
Happens with all strings: Modern, Classic, System...
09-27-2017 09:55 AM
It was already reported (CAR# 667716).
