Most suitable FFT function
There are many FFT function in LV as attached.
I am trying to acquisit a short waveform from 5133 and make fft and get s(f).
Then it is needed to calculate F as the attached.
This is for a realtime display of the waveform and F value.
May I know which method or function I should use, thanks.
(3,445 Views)
Hello Turbot,
Which functions that you have tried so far and what was the outcome of those functions that you have tried? Are they not fit for your use?
James
- Meadow -
LabVIEW 7.0 - 2011, Vision, RT, FPGA
TestStand 3.0 - 4.5
(3,378 Views)
Accepted by alex.
I dont have the required drivers and the vi attached is viewed as pile of vi's one above another :))
LabVIEW signal processing vi's have two FFT vi's which give real-complex and other mag-phase as outputs.  You can use the appropriate vi's for the next stage of calculations youwould like to do.
What is the output you are expecting technically (not in terms of equation) after the entire processing block.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,364 Views)
