Monitoring and Alarming System for Blue M furnace
Thak for your help, We gave the proposal and it was approved and We are inprocess of getting the hardware for the project, meanwhile I have a question; As you know the controller we are using has the communication opion, if we go for the communication option using the RS 485 how do I start and set up and get the output desired, and what will be my hardware requirements. The controller used is the MIC 6000 and the link for the manual is  http://www.partlow.com/uploadedFiles/Downloads/MIC6000_DS705.pdf
Thank you
Brian
Message 11 of 45
(1,866 Views)
Hi Brian,
How do I enable the alarm after the temperature reaches 300 degrees and disable the alarm after the soak period, can you explain this in detail.
Thank you
Nandan
Message 12 of 45
(1,838 Views)
Let me know how much Labview programming you have done.  If you haven't done much, this would be a good one to start with.
Message 13 of 45
(1,829 Views)
Hi Brian,
I havent done much I started out doing with the Temperature Monitor VI, Running Average, temperature control if the temperature is greater than the set temperature..can you tell me how to start and proceed further.
Thank you
Brian
Message 14 of 45
(1,821 Views)
I am looking at the example Temperature system Demo.Vi in the examle finder, I find it similar to what I want, but the only thing is to enable the alarm after it reaches 300 degrees and disable it after the soak time(1 hour). can you help me in modifying the circuit, can any one help.....
I am sending you the file as an attachment incase you cant find it.......
Message 15 of 45
(1,802 Views)
I guess I am not sure what hardware you ordered.  What is the list of hardware you will be working with?
Message 16 of 45
(1,793 Views)
I am planning on working with USB 9211 for the data acquisition.. Do I need anything else.. I thought of putting forward the logic first and get an approval from the manager and buy the software.,, Is USB 9211 fine or do I have to o for anything better... We are right now more concentratd to show that the program works to our manager.
Also the controller is showing the following measurements as per the Thermocouple.. I am sending you the attachment of it.
Thank you
Brian
Message 17 of 45
(1,783 Views)
I don't understand why you are using the USB DAQ to get you temperatures when you can get them from the controllers.
Message 18 of 45
(1,765 Views)
We get the temperature on the controller but how do we get them on to the computer,, what is the hardware we require to get the temperature readig on to the computer and then how do I interface the computer with the controller, and then how can Labview read the temperature and how do we perform the program. Can you please give the information in detail.
[ The reason I thought of using the USB DAQ because the controllers were very old and I donot want to mess up anything with the controller which will delay the production, so I thught of directly taking the readings from the thermocouple]
Of the two ways which is the best way and hardware required for the preferred way and how to procedd on to it.
Please help ....
Message 19 of 45
(1,761 Views)
The cheapest route would be to communicate with the controllers, but you have to know how to do that.  The easiest would be to use the T/C Daq device.  Are you not using a Windows environment?  I'm not sure why you provided the voltage vs temperature data.  Am I missing something?
Message 20 of 45
(1,751 Views)
