Monitoring RS232 Communication
Please is there a way to monitor RS232 communication traffic via VI?
(5,680 Views)
The NI-VISA VIs work very well for this.
(5,674 Views)
Put a VISA Read inside of a loop.  You will likely need to setup the port before the loop to make sure you have the right baud rate and other settings.  Look in the LabVIEW Example Finder (Help->Find Examples) for Simple Serial.vi for a decent place to start.
(5,649 Views)
What I am really looking for is somehting that works similiar to hardware loop back. Using only software, I need to be able to monitor what is being sent out as well as what is being received. Thanks.
(5,608 Views)
Accepted by aderogba
Ot sounds like you want to "see" what the serial port is doing while another program is using the port like a port sniffer?
If so LabView will not do that as LabView and Ni-VISA must have access to the serial port.
If another program is using the port NI-VISA and LabView will be locked out.
If you start a LabView porgram first NI-VISA will lock the port so no other program can access it.
I believe you need a program like PortMon part of the Sysinternals Suite from MS Technet.
=== Engineer Ambiguously ===
(5,600 Views)
Or NI IO Trace (NI-Spy), which is probably already installed on the machine...
http://www.ni.com/download/ni-io-trace-3.1.1/4285/en/  if it's not.
(5,581 Views)
