Monitor a device using the same device
I have an application that uses NIDAQCard-DIO24. It is already an executable VI built in LabVIEW 5.1.1 and I do not have the original VIs with block diagram.
How can I capture everything that this application writes/reads using the same card?
Message 1 of 8
(3,926 Views)
Hi
I'm not sure but I think this is not possible.
If you have your executable running, any other vi won't access this device because it is already in use.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 2 of 8
(3,918 Views)
I agree with becktho, if you try and access a DAQ card being used by another application, or even another VI you will get an error telling you roughly "this resource is busy".
Putnam Monroe
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 3 of 8
(3,913 Views)
It is the same as the serial port.
Just start one terminal which opens com1 and then start another termin and try to open com1 again.
You'll get a message that com1 is not accessible.
Thomas
Using LV8.0
Message 4 of 8
(3,906 Views)
Thanks for your reply.
However, there is a function in one of DAQ's dll called DAQ_monitor. I think it can help my concern but I am not that good at this level.
Can you dig deeper?
Message 5 of 8
(3,900 Views)
The DAQ cards' resources will be reserved since your EXE is using that DAQ card, and the function that you plan to use will not execute properly considering that you will write a program (text-based)to use the function.
Message 6 of 8
(3,869 Views)
I am planning to use Call Library Function.
Anyway, I am not giving up this topic. I strongly believe that it can be done but I am looking forward a very hard working days ahead of me. I'll just inform you if I'm successful.
Message 7 of 8
(3,858 Views)
You do not go for the easy stuff do you?
If you REALLY want to walk that path, I will offer the only hint that I can.
Re-write the dll that is called by NI-DAQ.
Your re-write will have to echo the calls to the original dll and add the extra functionality of leting you eaves drop on the activity.
In the meanwhile, could you share with us what the LV 5.1.1 program does that you do not want to re-write?
Who know, maybe one of wrote it and still has the source.
Ben
Message 8 of 8
(3,841 Views)
