Modify Event Structure to Have Continuous Data Acquisition Shown on Graphs
Hi Everyone,
I have asked a similar question before with the same VI I wrote, and it seems like I didn't frame my question correctly. I will explain it more clearly, and I am attaching my VI below.
So when I am running my VI, the graph updates every N samples. Let's say I set "Samples per loop" to 10000 and the "sample rate" to 1000, the graphs will update every 10 seconds, and the x is a 10 seconds frame. I want the graphs to be continuously updating and x (t) will increase all the time. Because I am building my VI on the basis of an example, the event in the event structure is "Every N samples acquired into buffer". And I think this is exactly why the graphs only update when it has "N samples".
Is there a way to restructure the "Event structure" to make the graphs update continuously, not every 10 secs even with a large "samples per loop"?
Thank you very much.
(3,458 Views)
When you get your samples you can put them in a queue. In a separate loop, you can dequeue the samples and wire to a chart.
(3,436 Views)
I'm not even seeing a point in the Event Structure in your example.  You can just tell the DAQmx Read to read your desired number of samples and let that limit your loop rate.
(3,418 Views)
Thank you for replying. To be honest, I don't even see the point of using a Event Structure as well. But I started building the VI on top of an existing example, it already had an Event Structure. And actually, this VI worked well on data acquisition, it's just that I want it to do better at live data readings (graphing).
And the weird thing is that when I eliminate the event structure completely, the VI doesn't work properly.
Could you advise me on how to take out the event structure?
(3,378 Views)
Accepted by tingggggg
Here is a cleaned up version of your code without the event structure.
(3,371 Views)
Thank you so much Crossrulz! This does make perfect sense, I will test it out!
Have a great day.
(3,367 Views)
