Modifier la gamme d'une glissière à l'intérieur d'un cluster
Bonjour,
Je cherche à modifier, à partir d'un noeud de propriété,la gamme de l'échelle d'une glissière, lorsque celle-ci est à l'intérieur d'un cluster. Je sais faire la manip pour une glissière seule, mais n'y arrive plus lorsqu'elle est dans un cluster.
Merci de votre aide.
Raphaël Khawam
(2,744 Views)
Accepted by topic author raph.khawam
Thanks for posting on the National Instruments' forum. However, here is an English forum. Please post in English or post on the French forum.
In order to modify the range of your Pointer Slide in a cluster, use "VI Server Reference" in the "Application Control" Functions panel. Then, with a left click, choose Pane-->Cluster-->Slide. Finally, add a "Property Node" and select what parameter you would like to change.
Please find as attachment the VI I built to illustrate what I just explained to you. I saved it in LabVIEW 2009 for the compatibility.
Tell me if it's what you was looking for.
Jérémy C.
NI France
(2,728 Views)
I coudn't open the VI you sent me although i followed your instructions and it did work out.
cheers.
Raphaël K.
(2,721 Views)
