Modified Histogram LabVIEW Code
Hello everyone,
I have a simple algorithm that I need to put into LabVIEW. I already have the pseudocode typed up, and it works when I coded it in Java, but for some reason, the translation into pictures is giving me a hard time. Basically, I want to do some array manipulation so that I can get a quasi-histogram. However, I don't want the histogram to tell me all of the occurrences within the array - just how many times it occurs in a row. I will provide an example below:
Input: Fuel = { 3900, 3900, 3900, 3900, 3900, 3900, 5000, 5000, 5000, 4000, 4100, 3900, 3900, 3900, 3900 }
Output:      Value = { 3900, 5000, 4000, 4100, 3900 }
Freq = { 6, 3, 1, 1, 4 }
There is a post out there that tells me how to generate a histogram, however, I need it slightly modified so that it doesn't search through the whole array, but rather just keeps a running counter and insert it into a new array everytime it finishes counting how many values were in that set.
Here is my start to the solution (attached as a PNG and a VI)
(4,744 Views)
Accepted by topic author ruthnan
Hi ruthnan,
it's a simple counting you need:
(4,738 Views)
Hi GerdW,
What is the true case here? I ran the code, but it didn't work as expected, maybe since I couldn't see what the true case is.
(4,727 Views)
Okay - I kind of got it working, but how do I only add array elements when it has finished counting? Right now, it increments for every index. I want to create a new array, that is not necessarily the size of the original array.
(4,725 Views)
Gerd's image is a snippet.  That means you can drag the image and drop it into a block diagram.  Then you can see what the true case has.
The main difference I see between his and yours is the location of the Build Array function.
(4,707 Views)
I see!! Thank you very much, RavensFan and GerdW! I was trying to drag from Google Chrome, but it was not working, so I dragged and dropped the snippet from IE. I will modify the code today.
(4,689 Views)
I think only IE handles the image properly.  Maybe another browser.  Chrome and I think Safari have problems.
With the browsers that have problems, if you save the image to your computer, then you can drag and drop that file to your block diagram.
(4,687 Views)
